Generic Serial Flash Interface IP Problem: In BSP Editor the Linker Memory Region for flash Missing
- 5 years ago
Hi.
I have found the problem and solution, see:
Quoted from above link:
SEVERE: CPU "cpu" reset memory "qspi_flash_avl_mem" has no matching memory region
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 20.1 and earlier versions, you may see below errors when creating a new NiosII® software project if NiosII®’s reset vector is set to a Generic Serial Flash Interface IP:
SEVERE: CPU "cpu" reset memory "qspi_flash_avl_mem" has no matching memory region.
WARNING: Tcl script "bsp-set-defaults.tcl " error: CPU "cpu" reset memory "qspi_flash_avl_mem" has no matching memory region.
SEVERE: [Error] altera_hal_linkerx_generator: Required linker section mappings do not exist: "[.entry, .exceptions, .rodata, .rwdata, .text, .bss, .heap, .stack]"
SEVERE: [Error]altera_hal_linkerx_generator: Required linker section mappings do not exist: "[.entry, .exceptions, .rodata, .rwdata, .text, .bss, .heap, .stack]"
SEVERE: nios2-bsp-create-settings failed.
Workaround/Fix
This problem has been fixed in the Intel® Quartus® Prime Pro Edition version 20.3."
