CBisc2
6 years agoGeneric Serial Flash Interface Intel FPGA IP with disabled dedicated Active Serial Interface
Hello, I am currently using an Cyclone 10 LP in Quartus 18.1 with an EPCS16 device for configuration for FPGA and NIOS II application. This is basically working with the legacy Serial Flash Control...
ShafiqY_Intel
6 years agoHi Christopher,
I'm sorry for late reply.
Regarding to your sentence "using the index 0 of the vectors for dataout and datain", can I get further explanation? I didn't get you here.
I think before testing the booting, I need to get the confirmation from you whether you are able to access the flash with GSFI or not?
Have you tried read flash ID or do simple read & write to flash using GSFI? everything is working fine?
This to make sure the hardware connection is working.
Cheers
