Generic Quad SPI Controller II IP questions
Hi
Sorry for the confusion. Yes you are right. Thanks for raising this up to us.
The behavior is indeed that WEL needs to be manually toggled for Sector Protect, Sector Erase and Bulk Erase.
This behavior will be documented in the document.
We are in the midst of doing the documentation update.
Jingyang, Teh
Thanks for the update and I'm glad that our findings align.
I would recommend that Intel re-investigate the clock rate (Question #5 in the original post). My sims and FPGA builds show that the design and PROM interface meet timing and behave as expected when the clock rate is 100MHz. Maybe this is only true for Micron PROMs because I have not simulated with Intel PROMs.
Please consider this support request accepted and closed and thanks again.
Terry
