Generic Quad SPI Controller II IP questions
Hi Terry
Sorry for the late reply.
Justo get back to you on point 2. Regarding the WEL Control.
Which IP Version you are using currently? There was a bug fix for this issue after the 19.1 IP update.
Could you try it out with the version 19.1 or above?
The Generic SPI Controller II IP gives more flexibility to the user in terms of the setting manipulation where as the Generic Quad SPI Controller II is not.
The timing parameters of above 40MHZ are not recommended for the Generic SPI Controller II IP.
Jingyang, Teh
- Terry63 years ago
Regarding question #2, I'm using IP version 20.1.2 which should have the bug fix you're referring to.
Setup: Intel Cyclone 10 GX, Micron MT25QU256 PROM, Quartus 22.3, IP version 20.1.2
My sims show that with the MT25QU256 PROM that the WEL is not asserted for Sector Protect, Sector Erase, or Bulk Erase operations.
Maybe this is a situation in which the IP core WEL behavior supports the Intel EPCQ devices but does not support the Micron MT25QU256 device operations in the above cases? That seems strange because both devices require WEL to be asserted for these operations.
Thanks again,
Terry
