8 years agogenerating UFM programming file without recompile
Hello, My company is planning to start producing hardware with MAX10 device on it and i want to store unique identifier in each one of them. I know how to achieve that with on chip flash IP, qs...
8 years ago --- Quote Start --- in Convert Programming Files Mode "Internal Configuration" Pres "Option/Boot info..." in UFM source select "Load memory file" in File path add hex for UFM and next add SOF as you did --- Quote End --- Thank you very much. That is exactly what i need. I was in "Option/Boot info..." tab before and didn't notice UFM option. --- Quote Start --- search "Max10Neek_My_First_NiosII" p.62 "3.3 Programming On-chip Flash" And in general this document is the best that I found to create the first project on nios for MAX10! --- Quote End --- Thank you again. I will definitely read this.
