8 years agogenerating UFM programming file without recompile
Hello, My company is planning to start producing hardware with MAX10 device on it and i want to store unique identifier in each one of them. I know how to achieve that with on chip flash IP, qs...
8 years ago --- Quote Start --- Hi Vitalyi, i tried to use Convert Programming Files but without success. When i choose pof as an output programming file and internal configuration as a mode, only input i could add was one sof. Add Hex Data button was greyed out. Maybe my settings were wrong. --- Quote End --- in Convert Programming Files Mode "Internal Configuration" Pres "Option/Boot info..." in UFM source select "Load memory file" in File path add hex for UFM and next add SOF as you did --- Quote Start --- Is there any documentation for Convert Programming Files utility? I can't find any. --- Quote End --- search "Max10Neek_My_First_NiosII" p.62 "3.3 Programming On-chip Flash" And in general this document is the best that I found to create the first project on nios for MAX10!
