8 years agogenerating UFM programming file without recompile
Hello, My company is planning to start producing hardware with MAX10 device on it and i want to store unique identifier in each one of them. I know how to achieve that with on chip flash IP, qs...
8 years agoin Convert Programming Files
Mode "Internal Configuration" Pres "Option/Boot info..." in UFM source select "Load memory file" in File path add hex for UFM and next add SOF as you did //Maybe my settings were wrong. Is there any documentation for Convert Programming Files utility? I can't find any. http://www.terasic.com.tw/attachment...rst_niosii.pdf or search "Max10Neek_My_First_NiosII" p.62 "3.3 Programming On-chip Flash" And in general this document is the best that I found to create the first project on nios for MAX10!
