8 years agogenerating UFM programming file without recompile
Hello, My company is planning to start producing hardware with MAX10 device on it and i want to store unique identifier in each one of them. I know how to achieve that with on chip flash IP, qs...
8 years agoHi Vitalyi,
i tried to use Convert Programming Files but without success. When i choose pof as an output programming file and internal configuration as a mode, only input i could add was one sof. Add Hex Data button was greyed out. Maybe my settings were wrong. Is there any documentation for Convert Programming Files utility? I can't find any. I'm not sure what do you mean by linking two files. I tried to found location of ID in final pof and edit it with hex editor, but then programmer complained that pof was corrupt so there must be some checksum. I can't find anything about that neither but i think it is because pof is not supposed be edited manually. Thank you, i appreciate your help. I'm new in Altera devices and tools so maybe i'm missing something obvious.
