Thanks for the replies.
I have decided to use a Tausworthe generator which consists of three LFSRs. If anyone is interested, check out this link: http://www.ams.org/journals/mcom/1996-65-213/s0025-5718-96-00696-5/s0025-5718-96-00696-5.pdf. At the end there is an implementation of the generator in C. Regards - Altera_Forum
TO_BE_DONE
Did you have a question, or were you showing off your latest and greatest code?
No,Thank you.
For those interested in a synthesizable core for generating normally distributed random numbers (often used for additive white Gaussian noise - AWGN), we offer affordable IP cores for Altera FPGAs that generate normally distributed numbers accurate up to 7.2 standard deviations.
Look up the Ukalta Engineering website for more details.
