11 years agoGenerating a pulse train at specific time on FPGA using VHDL programming.
Hello everyone. I am new to VHDL programming and FPGA. I would to generate a pulse train at specific time on fpga using vhdl programming. The whole process is that 1. PC sent an arra...
11 years agoOkay, First you need to know that you are working with hardware which executes parallel. So basically everything runs at the same time. If you need a delay, you build a timer and do something depending on this timer. You could start by making something basic. One of the first things I did was building a "knight rider" effect. It is a shift register that is connected to some leds. Each led is turned on and of in time, and when the last one is lit the effect is reversed. This uses some basic elements like a shift register, a counter and a little more sophisticated element: a prescaler.
I would start by something like that before drowning yourself in protoocols, memory and floating/fixed point.
