11 years agoGenerating 400MHz external clock (Cyclone V)
Hello, I'm trying to generate a 400MHz clock signal from my Cyclone V in order to drive the clock input for an external ADC, but I'm getting severe attenuation on the clock signal. Details: ...
11 years agoHi si09ath,
Perhaps you might want to share the screen shot so that everyone could have better idea what you are facing. I don't think there are any hardware limitation on FPGA to output 400Mhz but if you would like to confirm that, instead of output using ALTLVDS. Use the SERDES to output a repeated 10101010 Also I don't think there is anything wrong with a 1 GHz scope unless is setting. Try pressing the AUTO button then let the scope final best setting to probe. Then check the board if there if there are any cap
