12 years agoGenerate programming file for multiple device chain (HDL and Nios code)
I have a board that has two Cyclone IV devices on it. Each Cyclone will have it's own unique HDL and embedded NIOS processor. My question is how do I generate the programming file for the serial co...
12 years agoDo I assume you've captured a design implementing a 'Multi-Device AS Configuration' scheme, as found in the configuration handbook - Figure 8-3? Page 8-13.
http://www.altera.co.uk/literature/hb/cyclone-iv/cyiv-51008.pdf (http://www.altera.co.uk/literature/hb/cyclone-iv/cyiv-51008.pdf) Whilst this is designed to configure multiple devices from a single configuration device, I'm not sure how you can (easily) retrieve two separate software images for your two Nios' in two separate FPGAs. I don't think it's going to be as easy as adding a second set of .sof & .elf files to the config device. There's quite an amount of arbitration to consider to prevent both devices accessing the configuration device at the same time. Like I say, it can be done. Let me know whether I've interpreted your question correctly. Regards, Alex
