14 years agoGenerate patterns through CPLD(MAXII)?
I'm new to FPGA/CPLD. Could any one help me? I'm wondering if I can use CPLD/FPGA to generate some patterns to output pins? This is for some simple test purpose. For example, under 50MHz clo...
14 years ago --- Quote Start --- Before going that far, I need to generate serial patterns for some purpose. How can I generate serial patterns? --- Quote End --- With a parallel to serial shift register? Look at the documents on this page: http://www.ovro.caltech.edu/~dwh/carma_board/ (http://www.ovro.caltech.edu/%7edwh/carma_board/) http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf (http://www.ovro.caltech.edu/%7edwh/carma_board/fpga_configuration.pdf) http://www.ovro.caltech.edu/~dwh/carma_board/at84ad001b_tests.pdf (http://www.ovro.caltech.edu/%7edwh/carma_board/at84ad001b_tests.pdf) http://www.ovro.caltech.edu/~dwh/carma_board/ad9956_tests.pdf (http://www.ovro.caltech.edu/%7edwh/carma_board/ad9956_tests.pdf) They all have examples of devices with serial interfaces, along with the FSM designs. Just copy something in there. If you want to generate a long sequence of random bits, then use an LFSR: http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/lfsr_tutorial.pdf) These sequences are not really random, in that they follow a well defined pattern. You can generate an LFSR serial pattern, capture the first few bits and use that as a seed to a receiver-side LFSR checker. This is how the Altera pattern-generator and pattern-checker cores work. Cheers, Dave
