14 years agoGenerate patterns through CPLD(MAXII)?
I'm new to FPGA/CPLD. Could any one help me? I'm wondering if I can use CPLD/FPGA to generate some patterns to output pins? This is for some simple test purpose. For example, under 50MHz clo...
14 years ago --- Quote Start --- I can have 8Mbits SDRAM from DE0 board, but I don't know if this is dual-port. Also, I need to purchase Avalon-MM IP. Right? --- Quote End --- I don't think you'll need to use the off-chip RAM unless your patterns are really long. If they are, then no problem, you can use the SDRAM controller provided by Altera, and a DMA controller within the FPGA to stream from the SDRAM controller to a FIFO target, and the other side of that FIFO can be your test pattern logic generator. If you need random patterns then you can use a linear feedback shift register to do the job: http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf Cheers, Dave
