14 years agoGenerate patterns through CPLD(MAXII)?
I'm new to FPGA/CPLD. Could any one help me? I'm wondering if I can use CPLD/FPGA to generate some patterns to output pins? This is for some simple test purpose. For example, under 50MHz clo...
14 years agoYou must specify what do you mean for medium size: tens of bits, hundreds, thousands?
The optimal solution is different in these cases. I dare say that for a pattern less than 100bits long which needs to be changed occasionally you can simply use a CPLD and the shift register solution. Usually the shift register blocks (I refer now to lpm_shiftreg) have a LOAD input which loads all data from a parallel port and/or a SHIFTIN input to load serially. For each clock edge, stored data is sent serially out of a SHIFTOUT port, and this is the pattern you want to generate. Parallel load is not convenient in your case; discard it and connect all other shiftreg input ports to external controls (push buttons, PLC or microcontroller outputs): you can do everything with these few signals. PLease note that minimal extra logic inside CPLD may be required if you need the pattern to be generated under particular conditions.
