12 years agogenerate music box; two or more push buttons as inputs
Hello! Could you help me in my project? My project is a music generator using DE1 module. similar to this music box http://www.fpga4fun.com/musicbox3.html. When I pushed KEY0 push button, it will pla...
12 years agoAs the link you included suggests you need to create ROM images, one for each tune you wish to play, containing all the samples and timing required by each tune. Your logic will then, based on a key press, replay the chosen samples (from the appropriate ROM) to the DAC on the DE1. You may well need to cascade a number of M4K memory blocks for the longer tunes.
