18 years agoGenerate block of verilog
Hi Sir,
I am studying Verilog language. Below is a exercise about 'Generate ' and 'Task'. The quartus compiler report 'Can't resolve multiple constant drivers for net "tsk.outdata" at test.v(12)' . Could anyone help me? Thanks. //////////////// module test(clk,sel,in,out); input clk; input sel; input in; output [1:0] out; genvar i; generate for(i=0;i<2;i=i+1) begin: replicate always @(posedge clk) begin tsk(sel,in,out[i]); end end endgenerate task tsk; input select; input indata; output outdata; begin case (select) 0: outdata=indata; 1: outdata=outdata; endcase end endtask endmodule ////////////////2 Replies
Hi HDL Guru,
Thanks alot. - Altera_Forum
The output variable in the task has a static lifetime. You're basically saying, "If select = 1, then output holds its previous value, e.g. the value you assigned it from the last time select = 0". That is, each call to tsk potentially assigns a value to outdata; hence, there are multiple drivers.
Admittedly, the tool could generate a more useful error. In theory, it could create a latch for outdata and resolve all possible calls to the task. It's better to avoid this coding style, or declare your task as automatic.
