16 years agoGenerate 1Hz clock from a 50MHz clock
I want to generate 1Hz clock with 50% duty from 40MHZ input clock to MAX II CPLD. I had known to keep the 40MHz clock as input then use the generated 1Hz clk signals from the counter divisions as ...
16 years agoTo josyb,
Yes, you are probably right, because the overflow value is fixed at compile time, counting up or down should not make a difference. But for other cases it does, so I try to always count down, that way if I latter want to change the design to be a bit more dynamic then I do not have that many changes to make and I still get optimal results.
