16 years agoGenerate 1Hz clock from a 50MHz clock
I want to generate 1Hz clock with 50% duty from 40MHZ input clock to MAX II CPLD. I had known to keep the 40MHz clock as input then use the generated 1Hz clk signals from the counter divisions as ...
16 years ago --- Quote Start --- I wonder why these manufacturing people keep changing things and making our life at field a bit hard. --- Quote End --- Although offered as a "CPLD", MAXII is actually a family of small SRAM based FPGAs with nonvolatile configuration. I assume, it's the only way to achieve a similar logic complexity. I won't expect a typical small CPLD design to be slower with MAX II. Unfortunately, josyb's test code doesn't work with MAX3000 CPLD, Quartus says to use latches and doesn't give a meaningful timing analysis.
