16 years agoGenerate 1Hz clock from a 50MHz clock
I want to generate 1Hz clock with 50% duty from 40MHZ input clock to MAX II CPLD. I had known to keep the 40MHz clock as input then use the generated 1Hz clk signals from the counter divisions as ...
16 years agoFast isn't one of the adjectives I'd use for traditional CPLDs. Nor flexible.
MAX II are generally faster and much more capable than MAX x000 series.
