16 years agoGenerate 1Hz clock from a 50MHz clock
I want to generate 1Hz clock with 50% duty from 40MHZ input clock to MAX II CPLD. I had known to keep the 40MHz clock as input then use the generated 1Hz clk signals from the counter divisions as ...
16 years agoto amilcar,
I don't think (in fact I'm almost sure) counting down makes a difference, you need all bits to do a comparison anyway?
