16 years agoGenerate 1Hz clock from a 50MHz clock
I want to generate 1Hz clock with 50% duty from 40MHZ input clock to MAX II CPLD. I had known to keep the 40MHz clock as input then use the generated 1Hz clk signals from the counter divisions as ...
16 years agoI would rather use 25 bits and avoid the analysis of cascaded counters.
You are not counting the overheads of each division which needs a toggle signal per stage as well as logic to detect the max count. note also that cpld hasn't got LUT as fpga
