12 years agoGeneral questions from a first time user...
Hello all, I have recently discovered FPGA's thanks to Grant Searle's web site, which contains instructions on how to program a Z80 computer on an Altera EP2C5T144C8N mini board. Essentially, I've...
12 years agoHi,
--- Quote Start --- Thank you for the small tutorial. I had a few problems getting it going, being that I have learned to run before I can walk, but persistence paid off, and I was able to generate the qwork directory. --- Quote End --- It sounds like you did not read the readme.txt file included with the example. I have updated the zip file and removed the qwork folder (to avoid the confusion it caused). Please follow the readme.txt instructions (repeated here):
Terasic DE1 'basic' example
4/25/2012 D. W. Hawkins ([email protected])
Terasic DE1 Cyclone II FPGA kit 'basic' design.
Counters are used to blink or generate counts using the three
onboard clock sources as follows;
* KEY is used as the reset input
* KEY drive the 3 MSBs of the red LEDs
* 7 switches connected to 7 of the 10 red LEDs.
* 8 green LEDs blinked using the 24MHz clock
* Hexadecimal displays A and B count based on the 27MHz clock
* Hexadecimal displays C and D count based on the 50MHz clock
The design can be synthesized as follows;
1. Unzip the example design into
c:/temp/de1_basic
when using windows to unzip the file, unzip
de1_basic.zip into c:/temp and the folder
c:/temp/de1_basic will be created.
2. Start Quartus II.
3. Click in the Tcl console.
If the Tcl console is not visible, bring it up
using View->Utility Windows->Tcl console
4. Use the Tcl console to change to the directory to
the de1_basic/ folder, eg., at the Tcl console type
tcl> cd {c:\temp\de1_basic}
Where 'tcl>' is the console prompt.
The parathases {} pass the Windows format directory
to Tcl as a list variable. This allows you to copy
and paste the directory path from Windows Explorer.
5. Run (source) the synthesis script
tcl> source scripts/synth.tcl
The Tcl console will then output the build sequence:
Synthesizing the DE1 'basic' design
- Quartus Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Full Version
- Creating the Quartus work directory
* C:/Temp/de1_basic/qwork
- Create the project 'de1'
* create a new de1 project
- Creating the VHDL files list
- Applying constraints
- Processing the design
- Processing completed
6. Download the design
Plug in the DE1 USB-Blaster and download the .sof file.
The LEDs and hex displays should start to blink/count.
Read the comments in src/de1.vhd for details on the basic design.
Enjoy!
Cheers,
Dave
7/12/2014: Checked synthesis with Quartus 13.0sp1.
Updated the readme.txt. No code changes.
Cheers, Dave
