General questions from a first time user...
I understand it then, that there's a bit more to just compiling the software for the other board. It seems like I would not only have to compile the software, but also look through the pin assignments. I guess I would also have to specify where the software is to find the ram and VGA port, and opposed to where the software was written to find the peripherals. I should mention that I was able to successfully go through Grant Searle's Multicomp project and build the project with external ram, VGA and ps/2 ports on the mini board. I was hoping this might be somewhat of a straight forward process, but it looks like I may need to take a few steps back, get a few tutorials under my belt, and then try to understand how to port a project. Thank you for the reply.
