10 years agoGeneral question about Soc CycloneV and ARM with or without linux.
Hi every boby,
a naive question, is it possible to use a cycloneV SoC with ARM without linux. With Nios, it is OK an OS or RTOS is not necessary. I haven't found the answer yet. Thank you to help. Garfielminou.2 Replies
Hi SusannahM,
Tank you for your help. I am going to follow your advice. Garfielminou. - Altera_Forum
Yes! In fact, if you install SOC EDS, it comes along with a ton of libraries to help you code in baremetal, and examples. There are also examples here: https://www.altera.com/support/support-resources/design-examples/soc.html
With Nios, it's also perfectly acceptable to code in baremetal. There are examples included in the Nios II EDS that comes installed in Quartus.
