9 years agoGeneral question about EEPROM
Hi I recently had a problem with my dev kit- when I plugged it in to my computer, it showed up as a USB serial device as opposed to a USB blaster. The extremely helpful forummers here informed me ...
8 years ago --- Quote Start --- Also, there should be another connector for USB Blaster which uses the 10 pin male header for JTAG programming to the FPGA. --- Quote End --- There's no 10-pin header for FPGA JTAG programming at the DE2-70 kit the user is asking about. Only an unpopulated header for USB Blaster CPLD factory programming. --- Quote Start --- The two functions you speak of are located in two different non-volatile memories (EEPROM) on your board. --- Quote End --- Yes, the previous FPGA program is stored in EPCS16 AS flash.
