16 years ago
gating the output of a clocked register onto pins
I have a simple process in a max 2 that writes and is supposed to read a register array and put the data onto device pins- the same pins I use to write data to the register.
It is really simple:
register_process: process(localclk, reset_pulse, reset_flash, Dcsn)
begin
if localclk'event and localclk = '1' then
if Dwrn = '0' and Dcsn = '0' and Drdn = '1' then
case Daddr(3 downto 0) is
when "0000" => reg0 <= Data(2 downto 0);
when "0010" => reg2(7 downto 0) <= Data(7 downto 0);
when "0011" => reg2(15 downto 8) <= Data(7 downto 0);
when "0100" => reg2(23 downto 16) <= Data(7 downto 0);
when "0101" => reg3 <= Data(7 downto 0);
when "0110" => reg4 <= Data(7 downto 0);
when "0111" => reg5(7 downto 0) <= Data(7 downto 0);
when "1000" => reg5(15 downto 8) <= Data(7 downto 0);
when "1001" => reg5(23 downto 16) <= Data(7 downto 0);
flash_load <= '1';
when "1010" => reg6(7 downto 0) <= Data(7 downto 0);
when "1011" => reg6(15 downto 8) <= Data(7 downto 0);
when "1100" => reg6(23 downto 16) <= Data(7 downto 0);
pulse_flag <= '1';
when others => null;
end case;
elsif Drdn = '0' and Dcsn = '0' and Dwrn = '1' then
when "0000" => Data(2 downto 0) <= reg0;
when "0001" => Data(7 downto 0) <= quad_count;
quad_reset <= '1';
when "0010" => Data <= reg2(7 downto 0);
when "0011" => Data <= reg2(15 downto 8);
when "0100" => Data <= reg2(23 downto 16);
when "1101" => Data <= keys(7 downto 0);
when "1110" => Data(2 downto 0) <= keys(10 downto 8);
end case;
elsif reset_pulse = '1' then
reg6 <= "000000000000000000000000";
elsif reset_flash = '1' then
flash_load <= '0';
else
Data <= "ZZZZZZZZ";
quad_reset <= '0';
end if;
end if;
end process register_process;
The problem is that data is correctly written and I can see it on the Q pins of the ffs but I can't seem to get it back on the device pins.
I know I am forgetting something and I hope someone will just put me out of my misery and tell me what it is.
Thank you,
1 Reply
    You can use an interim signal set and then gate that set onto the pins external to the process:
    Register_Process: Process(Localclk, Reset_Pulse, Reset_Flash, Dcsn)
    Begin
    If Localclk'Event And Localclk = '1' Then
    If Dwrn = '0' And Dcsn = '0' And Drdn = '1' Then
    Case Daddr(3 Downto 0) Is
    When "0000" => Reg0 <= Data(2 Downto 0);
    When "0010" => Reg2(7 Downto 0) <= Data(7 Downto 0);
    When "0011" => Reg2(15 Downto 8) <= Data(7 Downto 0);
    When "0100" => Reg2(23 Downto 16) <= Data(7 Downto 0);
    When "0101" => Reg3 <= Data(7 Downto 0);
    When "0110" => Reg4 <= Data(7 Downto 0);
    When "0111" => Reg5(7 Downto 0) <= Data(7 Downto 0);
    When "1000" => Reg5(15 Downto 8) <= Data(7 Downto 0);
    When "1001" => Reg5(23 Downto 16) <= Data(7 Downto 0);
    Flash_Load <= '1';
    When "1010" => Reg6(7 Downto 0) <= Data(7 Downto 0);
    When "1011" => Reg6(15 Downto 8) <= Data(7 Downto 0);
    When "1100" => Reg6(23 Downto 16) <= Data(7 Downto 0);
    Pulse_Flag <= '1';
    When Others => Null;
    End Case;
    Elsif Drdn = '0' And Dcsn = '0' And Dwrn = '1' Then
    When "0000" => Outputsig(2 Downto 0) <= Reg0;
    When "0001" => Outputsig(7 Downto 0) <= Quad_Count;
    Quad_Reset <= '1';
    When "0010" => Outputsig <= Reg2(7 Downto 0);
    When "0011" => Outputsig <= Reg2(15 Downto 8);
    When "0100" => Outputsig <= Reg2(23 Downto 16);
    When "1101" => Outputsig <= Keys(7 Downto 0);
    When "1110" => Outputsig(2 Downto 0) <= Keys(10 Downto 8);
    When Others => Outputsig <= "Xxxxxxxx";
    End Case;
    Elsif Reset_Pulse = '1' Then
    Reg6 <= "000000000000000000000000";
    Elsif Reset_Flash = '1' Then
    Flash_Load <= '0';
    Else
    Data <= "Zzzzzzzz";
    Quad_Reset <= '0';
    End If;
    End If;
    End Process Register_Process;
    Outen <= Not Drdn And Not Dcsn And Dwrn;
    Data <= Outputsig When Outen = '1' Else "Zzzzzzzz";
