fused fpga and jtag
There is no change on the pin JTAG_EN. I want to know if there is someway to stop FPGA JTAG access without a board level change.
Is there a way that someone had programmed an image that may stop FPGA from accessible through JTAG ?
I have the FPGA replaced and now the board is working. the USB blaster can program the FPGA again.
I want to know any mechanism that could kill the JTAG interface on the Max10.
if JTAGEN isn't pulled high on the board and someone enabled JTAG pin sharing inadvertently, you loose JTAG access.
- kcheung3 years ago
Thanks for the reply. I have the question.
1. I am sure that the JTAGEN is pulled high,
2. when you mentioned "lose JTAG access", do you mean momentarily ? or you mean permanently ?
The symptom I have encountered is that there is no hardware modification and yet, I lost the JTAG access. After replacing the FPGA, the USB blaster works and I can program the FPGA again.
