fused fpga and jtag
There is no change on the pin JTAG_EN. I want to know if there is someway to stop FPGA JTAG access without a board level change.
Is there a way that someone had programmed an image that may stop FPGA from accessible through JTAG ?
I have the FPGA replaced and now the board is working. the USB blaster can program the FPGA again.
I want to know any mechanism that could kill the JTAG interface on the Max10.
- FvM3 years ago
if JTAGEN isn't pulled high on the board and someone enabled JTAG pin sharing inadvertently, you loose JTAG access.- kcheung3 years ago
Thanks for the reply. I have the question.
1. I am sure that the JTAGEN is pulled high,
2. when you mentioned "lose JTAG access", do you mean momentarily ? or you mean permanently ?
The symptom I have encountered is that there is no hardware modification and yet, I lost the JTAG access. After replacing the FPGA, the USB blaster works and I can program the FPGA again.
