14 years agofunctional simulation + STA = gate level simulation?
Hi: Is "functional simulation" + "STA" = "gate level simulation"? I designed a project,and run the functional simulation successfully,at the same time,the timequest timing analysis has no warnin...
14 years agoNo in general you don't need to run a gate level simulation, except if you have a bug on the running design that you think is linked to the compilation or a timing problem and want to track in down in the simulator.
If you are confident in your timing requirements specification, then the functional simulation and the Timequest report are enough.
