14 years ago
function error declaration in vhdl
hello guys ..i'm kind of new to this ..
i have a problem in vhdl function declaration .. i want to define function that calculate the avg of two std logic vectors .. but it keeps telling me that i have an error in the declaration .."Design unit declaration expected"
here is my code :
LIBRARY ieee;
LIBRARY ieee_proposed;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_signed.ALL;
USE ieee_proposed.std_logic_1164_additions.ALL;
function avg (value1,value2 :in std_logic_vector(31 downto 0)) return std_logic_vector(31 downto 0) is
variable result : std_logic_vector (31 downto 0);
begin
result= (value1+value2) /2;
return result;
end function avg;
i hope anyone can help ..
thnxx :)
    You're still using the non-standard package as evidenced by the call to 'conv_integer'. You should switch to using ieee.numeric_std package and use the 'to_integer' and 'to_signed', 'to_unsigned' functions in those packages instead.
    Kevin Jennings
    yes that really helped thank you .. actually i used these libraries because i needed them .. the declaration of the function was a small part of my project .. and it kept telling me that there was a problem in the declaration .. but now it doesn't ..
    so thanks alot :)
    package Average is
    function avg (value1,value2 : std_logic_vector) return std_logic_vector ;
    end;
    package body Average is
    function avg (value1,value2 : std_logic_vector) return std_logic_vector is
    variable res: integer;
    begin
    res:= (CONV_INTEGER(value1)+CONV_INTEGER(value2))/2;
    result:=CONV_STD_LOGIC_VECTOR(res,32);
    return result;
    end package body ;
    a function has to be declared inside something. So it has to be decalred inside a package, or architecture or a process. Functions do not exist on their own.
    Secondly - as you're new to VHDL, may I suggest you ditch std_logic_signed - it is a non-standard package. std_logic_vectors are not meant to represent numbers. VHDL is strongly typed, and has unsigned and signed types to deal with numeric vectors inside the numeric_std package (which is part of the VHDL standard).
