14 years agoFT2232H 245 Synchronous FIFO Mode problem
Hello Im very new to FPGA's and am still learning so please be kind if the problem is obvious :) i have a FT2232H set to 245 Synchronous FIFO Mode. i have a program on the pc using...
12 years ago --- Quote Start --- Could you give me more info on resistor value and where you have added it? Thanks --- Quote End --- I only needed the resistor when breadboarding the projrct. Once on pcb it was not needed as the two ftdi/fpga where only a few mm from each other. On the breadboard I placed it as close to the fgpa clk input as I could. I cant remember the value, I think it was 100ohm.
