14 years agoFT2232H 245 Synchronous FIFO Mode problem
Hello Im very new to FPGA's and am still learning so please be kind if the problem is obvious :) i have a FT2232H set to 245 Synchronous FIFO Mode. i have a program on the pc using...
13 years ago --- Quote Start --- yes :) thats correct --- Quote End --- I use morphic-ii from FTDI and the eeprom has channel A configured as FIFO 245. But, i can't see any clock(60MHz) in pin 32 of FT2232H. Is there any set we need to get 60MHz in pin 32 ? Is there any command to send by usb ?
