15 years ago
FSM problem
Heyy I'm trying to make a video game in vhdl on de0 board and I need help about the following FSM. No error or warning. Does anyone notice a mistake??
thankss.
type XY_REG_TYPE is array (0 to 19,0 to 9) of std_logic;
	type AB_REG_TYPE is array (0 to 3,0 to 3) of std_logic;
	type XY_NEXT_TYPE is array (0 to 19,0 to 9) of std_logic;
	type AB_NEXT_TYPE is array (0 to 3,0 to 3) of std_logic;
	type STATE_TYPE is (count,zero,left,down,right);
	signal m : integer range 0 to 9;
	signal n : integer range 0 to 19;
	signal c,d : integer range 0 to 3;
	signal ab_reg : AB_REG_TYPE;
	signal xy_reg : XY_REG_TYPE;
	signal ab_next : AB_NEXT_TYPE;
	signal xy_next : XY_NEXT_TYPE;
	signal state_reg, state_next : STATE_TYPE;
	signal T_reg, T_next : integer range 0 to 10;
	begin
        FSM1: process (clk, reset, n, m, c ,d)
		begin
			if reset = '1' then
				xy_reg(n,m) <= '0';
				T_reg <= 0;
				state_reg <= zero;
			elsif clk'event and clk = '1' then
				xy_reg(n,m) <= xy_next(n,m);
				T_reg <= T_next;
				state_reg <= state_next;
			end if;
		end process FSM1;
      FSM2: process (SW(1), BUTTON, xy_reg, ab_reg, state_reg, T_reg, T_next, m, n, c ,d)
		begin
			xy_next(n,m) <= xy_reg(n,m);
			T_next <= T_reg;
			state_next <= state_reg;
			case state_reg is
			when count =>
				if EndOfField = '1' then
					T_next <= T_reg + 1;
					if T_reg = 10 and SW(1) = '1' then
						state_next <= zero;
					else
						state_next <= count;
					end if;
				end if;
			when zero =>
				if BUTTON = "111" then
					if xy_reg(n+1,m) = '0' then
						xy_next(n,m) <= xy_reg(n+1,m);
						T_next <= 0;
					else
						T_next <= 0;
					end if;
				elsif BUTTON = "101" then
					state_next <= down;
				elsif BUTTON = "110" then
					state_next <= right;
				elsif BUTTON = "011" then
					state_next <= left;
				end if;
			when down =>
					T_next <= 0;
				else
					T_next <= 0;
				end if;
			when right =>
				if xy_reg(n,m+1) = '0' then
					xy_next(n,m) <= xy_reg(n,m+1);
					T_next <= 0;
				else
					T_next <= 0;
				end if;
			when left =>
				if m >= 1 then
					if xy_reg(n,m-1) = '0' then
						xy_next(n,m) <= xy_reg(n,m-1);
						T_next <= 0;
					else
						T_next <= 0;
					end if;
				else
					T_next <= 0;
				end if;
			end case;
                 end process FSM2;
    --- Quote Start ---
    and it is still unsolved so your ideas will be very helpful.
    --- Quote End ---
    It would help a lot if you tried to pin point your problem and post a lot less code.
    It seems that the state machine is only half recognised by the FSM viewer. It can list the states but not the transitions. I'm not sure, but you may have to stick to the two-process model that Altera describes in the guidelines for the state machine to be properly recognized by the viewer.
