SJadh1
7 years agoFrequent loss of transceiver CDR lock
Hello, I am using Arria10 GX development kit. I am working on USB protocol. I have configured transceiver in pcs direct mode. I am seeing that transceiver lose CDR lock(lockedtodata) signal frequen...
CheepinC_altera
7 years agoHi ,
Regarding the point#3, you would need to use oscilloscope to probe both the recovered clock from the CDR ie rx_pma_clkout and the input refclk to CDR to check for phase difference.
As for the CDR ppm tolerance, the max is =/-1000ppm only. You may refer to the device datasheet -> "CDR PPM tolerance" section for further details.
Chee Pin
