11 years agofrequency range of ADA HSMC daughter board for Cyclone III FPGA
Dear everyone, I am Peipei, I am using HSMC ADA daughter board with Cyclone III FPGA. I have generated a range of frequencies from 1KHz to 2MHz from the HSMC board via Cyclone III FPGA board (u...
10 years agoIf it's the Terasic board, It's a a pretty high performance adc/dac on board. They are using the transformers to go from differential to single ended.
There are several ADC/DAC boards out there. The DAC has a transformer bypass stuff option, you may want to try that. Pete
