13 years agoFrequency of operation of M9K bram
Hi, Does anybody know where/how to find the operating frequency of a block ram? I particularly need M9K and M10K. I was not able to find them in the altera documentation. Kindly let me know if ...
13 years agoHello Dave and rbugalho,
I somehow needed to get the RAM inferred. Dave...I tried what you told me to do in your previous post. When I instantiated the altsyncram component instead of my generic verilog code, M9K blocks are being inferred. I also tried wrapping the simple dual port RAM instead of the 2W4R RAM[ I have pasted the code below] in the test harness and synthesizing it. But I am facing the same problem. module my_memory_blocks( output reg [7:0] q, input [7:0] d, input [5:0] write_address, read_address, input we,clk ); reg [7:0] mem [511:0]; always @ (posedge clk) begin if (we) mem[write_address] <= d; q <= mem[read_address]; end endmodule When I click on the "Info (276004): RAM logic "my_memory_blocks:m0|mem" is uninferred due to inappropriate RAM size" it is pointing to the line in red in the above code. I cannot understand what is inappropriate in it even after following all the altera coding standards. I guess I will go ahead and file a service request as you said.
