13 years agoFrequency of operation of M9K bram
Hi, Does anybody know where/how to find the operating frequency of a block ram? I particularly need M9K and M10K. I was not able to find them in the altera documentation. Kindly let me know if ...
13 years agoHi rbugalho,
Thank you so much for the reply. Kindly find attached the modules of the RAM. 1) The module named MEM_2w4r.v is the entire RAM design. - This when synthesized alone , M9K blocks were inferred. 2) The module named test_harness.v is the test harness which is used to wrap the RAM design. The compilation report gave this message : Info (276014): Found 4 instances of uninferred RAM logic Info (276004): RAM logic "MEM_2w4r:m0|MEM_1w4r:MEM_1|MEM_1w1r:MEM_1w1r_0|memory" is uninferred due to inappropriate RAM size Info (276004): RAM logic "MEM_2w4r:m0|MEM_1w4r:MEM_1|MEM_1w1r:MEM_1w1r_1|memory" is uninferred due to inappropriate RAM size Info (276004): RAM logic "MEM_2w4r:m0|MEM_1w4r:MEM_1|MEM_1w1r:MEM_1w1r_2|memory" is uninferred due to inappropriate RAM size Info (276004): RAM logic "MEM_2w4r:m0|MEM_1w4r:MEM_1|MEM_1w1r:MEM_1w1r_3|memory" is uninferred due to inappropriate RAM size The RAM is used in Simple dual port mode, with depth = 256 and width = 32. Please suggest how I can overcome the issue.
