13 years agoFrequency of operation of M9K bram
Hi, Does anybody know where/how to find the operating frequency of a block ram? I particularly need M9K and M10K. I was not able to find them in the altera documentation. Kindly let me know if ...
13 years agoHi rbugalho,
I got what you are saying. I tried it. However I have a question.. I have synthesized a simple dual port ram having 32x8 depth and width. I use the TimeQuest Timing Analyser wizard to set the clock, input and output constraints. Setting the clock constraint is fine, but when I need to set the i/p and o/p constraints I need to select each of the 32 write data ports , 8 write and read address ports individually. Is there an easier way of doing this? Looking forward to your answer. Thanks.
