17 years agoFree on-line C to FPGA software
Hello, I wanted to recommend http://www.c-to-verilog.com (http://www.c-to-verilog.com/) ; This website has a free on-line compiler which lets users put regular C code and compile it ...
17 years agoI had a quick look at the basic ideas of c-to-verilog tool. What I would have preferred to see, a tool that takes care of resource-speed tradeoff. However the tool's module interface is based on free-running default sampling clock. This implies that it can only produce designs sampling on this clock.
Is there any way you can enter a clock enable signal to control processing for selected samples. This is very helpful for two reasons: -To constrain the module within the system's data flow srchitecture, otherwise the designer will nee extra memory to hold results. - Can be exploited to make the resource-speed tradeoff.
