    Hi DQ,
    The evaluation library works on any of the evaluation boards. You just need to select which board you are using when you build your application in the Nios II IDE.
    --eSOL
    We're not sure if the Cyclone will have sufficient MIPS for our application so we arranged to get a cyclone and stratix board to do some benchmarking. Does the evaluation software include support for all the NIOS II board, or are there different licenses?
    DQ
    Hi eSOL,
    I'm located in the UK. Do you have a representative in Europe I can contact for this evaluation?
    Is there also some sort of local support available?
    DQ
    Hi Uni.
    We support both Nios II IDE ver1.1 and 5.0. The supported boards are:
    * Stratix II Edition (EP2C30)
    * Cyclone Edition (EP1C20)
    * Stratix Edition (EP1S10)
    * Stratix Professional Edition (EP1S40)
    We will support the Cyclone II Edition (EP2C35) by mid June.
    eSOL
