SJadh1
7 years agofPLL loose lock debug help request
Hello, I am using Arria 10 GX FPGA Development board. I am debugging a fPLL lock issue. In current design fPLL instance gets reference clock from the recovered clock of transceiver. CDR block of...
SreekumarR_G_Intel
7 years agoHello Sachin,
Can you check the pll_cal_busy status ? if it is High can you disable the cal and check the same?
Also can you send me the fPLL setting with input and output Frequency ?
Thank you,
Sree
