16 years agoFPGA won't load from flash which contains hardware and NIOS software image
Set up is Cyclone3 with epcs128 serial flash. My FPGA includes the NIOS and epcs_controller. Using the Convert Programming Files tool, I covert my .sof file into a .jic file and then program t...
16 years agoI thought about that too, and I tried adding only the hw.hex to the .jic file... but I get the same problem, no conf_done after reset. However, if I go straight from hw.sof to .jic using the Convert Programming Files GUI... I don't have that problem as mentioned in my initial post.
Did your suggestion work for you?
