16 years agoFPGA won't load from flash which contains hardware and NIOS software image
Set up is Cyclone3 with epcs128 serial flash. My FPGA includes the NIOS and epcs_controller. Using the Convert Programming Files tool, I covert my .sof file into a .jic file and then program t...
16 years agooops the solution wasn't the one i was thinking of after all
try following the instructions from the solution but only including the hw.hex in your .jic file. it seems like the sw.hex is being put at the beginning of the EPCS causing the FPGA to fail configuration
