12 years agoFPGA to HPS SDRAM Interface
Hi, I want to use the FPGA to HPS SDRAM Interface, in kind of an Avalon MM Bidirectional 64 Bit. Logic is done, simulation results are as expected. I build the design and loaded it into the SoC...
12 years ago --- Quote Start --- Yes. When I posted the question I used Quartus 13.0SP1. It hat a bug regarding releasing the FPGA2SDRAM Bridge from reset. I had to switch to 13.1. Thomas --- Quote End --- So is there any registers to be set before fpga2sdram interface working?
