12 years agoFPGA Stratix II Pin assignment and control panel
Hi guys, I am using FPGA Stratix II board EP2S60F1020C3ES. I can't find the pin assignment for it also can not find the control panel .exe file to test the board any help will be appreci...
12 years agoHi Mourad,
--- Quote Start --- Since I can not provide link for the board. It can be seen on Altera website in the following sequence Home > Products > Development Kits/Cables > DSP Development Kit, Stratix II Edition --- Quote End --- Ok, here's a design for that kit. Keep in mind two things; 1. Stratix II devices require a Quartus II subscription edition. 2. The "ES" version of this board sucks, because the M-RAM does not work on the ES samples. (Unfortunately I have an ES version) I see the main Altera site doesn't have much info regarding this board any more. Let me know if you want the schematic or anything else, as I probably have the CD-ROM that shipped with the kit. Cheers, Dave PS. I just re-read your original post and see that you have the ES device - bummer. Make sure you edit synth.tcl to change to use the ES part number.
