12 years agoFPGA reconfiguration time
Hi Every one,
Is there any calculation regarding FPGA reconfiguration. When nconfig is pulled low for more than 500nsec and then release, reconfiguration will be initiated. But I couldn't able locate a method to know that what time it will take to reconfigure from serial configuration EPCS device (EPCS16S18N). Kindly help me. Thanks, Rajkumar3 Replies
Too long :-)
It depends on the amount of data to be loaded and the actual speed on the on-chip oscilator. There are some threads about failing to configure the fpga within the PCIe reset 'window' that give some indications of actual times. - Altera_Forum
Accepted, it will be too long but how much. Say I have 1MB pof, internal oscillator is 40MHz. I am looking for calculations, please provide if any available.
Thank you, Rajkumar - Altera_Forum
--- Quote Start --- Say I have 1MB pof, internal oscillator is 40MHz. I am looking for calculations, please provide if any available. --- Quote End --- The data sheet for the device and the configuration device generally has these calculations already. Essentially it is the .rbf file (not the .pof) length divided by the worst-case AS-mode clock frequency (or 33MHz typical). Cheers, Dave
