9 years agoFPGA re-flashing and running application from parallel flash
Hi, I am new to altera fpga, i am working on interfacing parallel flash with cyclone V board. After copying the binary/application from PC to parallel flash i need to run this application on fp...
9 years ago --- Quote Start --- Just to add... if this API will help me? static void ALT_INLINE alt_load_section (alt_u32* from, alt_u32* to, alt_u32* end) --- Quote End --- It is related to running code on a NIOS II soft processor implementation in an FPGA. If that is what you are intending to do then yes, otherwise not relevant.
