17 years agoFpga Programmer - Quest For Fuse
Hello, i'm in between a project and stuck with the design of safety of the system. I'm in need of the following fuses, :confused: 15 mA, 3.3V 75 micro-ampere, 3.3V 15 mA...
17 years agothank you for your valuble data...
i searched in http://www.digikey.com for 15mA fuses and found similar fuse, but the problem is it's has a voltage rating of 125v. :confused: Could i use this fuse in 3.3v circuitry ? thanks & regards varun v g
