11 years agoFPGA PLL Megafunction
Hi Everyone ! I am doing a project on an Altera Cyclone V FPGA. In this project I have a simple all-pass filter with severals I/O signals. Now I need to implement a PLL so that the output...
11 years agoHello David,
I think I would be able to help you in your third question. When you use Altera PLL( Cyclone V ) in your design, you need to add following pre-compiled libraries in your simulation configuration : In case of verilog (1) cycloneV_ver (2) altera_lnsim_ver In case of VHDL, (1) cycloneV (2) altera_lnsim You can find precompiled libraries from following location : <Quartus Installation Path>\13.0sp1\modelsim_ase\altera To add pre-compiled library,- On the Simulate menu, click Simulate.
- If you are simulating a Verilog HDL design, to specify the ModelSim-Altera precompiled libraries:
- Click the Libraries tab.
- In the Search Libraries (-L) box, click Add and select the appropriate libraries.
- Click OK.
